1997 Honda Civic - SRS Light on
I have had my SRS system tested with a response code of 02-2.
It tells me that the passenger air bag has an increased resistance on the inflator.
My problem is that the vehicle is not fitted with a Passenger airbag.
The vehicle is Right Hand Drive and the test was done through the Blue plug on the Left hand side.
Does the equipment then think that the vehicle is Left hand drive.
Therefore the test results are referring to the drivers side airbag having an increased resistance on the inflator.
Re: 1997 Honda Civic - SRS Light on
After a lot of research, I changed the dummy resistor in the passenger airbag loom (Factory Part).
Reset the computer and the SRS light went out and stayed out.
Now when I start the car SRS system goes through the test cycle and the light goes out and stays out (Fixed)
onyx00
11-30-2002 05:50 PM
