Gen 1 Honda Insight Ground Control coilovers
Re: Gen 1 Honda Insight Ground Control coilovers
Anyone rolling around on a ground control setup yet? I know i'm somewhat reviving a dead thread but i'm interested in seeing what options may soon be available for us gen1 owners.
I've had the GC's on my insight since i posted the prototype pics and i have replaced the rear shock with some from Monroe.
As for ride comfort, they are definitely much stiffer than stock but improve handling greatly in my opinion. No more "floaty" suspension feel at speed and door handle scraping cornering.
These are available on GC's website for all Gen 1 Insights.
If you want more info for Gen 1's in general, check out www.insightcentral.net
How many company's make coilover kits for the Insight besides GC and Tanabe? Seems like an older chassis but doesn't it work with the CR-Z as well?
I'm curious when you go lower with the Insight what type of camber kit do you use?
http://www.andysautosport.com/honda/...shims/ingalls/
TunerNoob, thanks for the info, I didn't know about those shims for the rears. I don't think I will use them since my alignment seems to be none the worse.
Here is my Insight lowered on GC's and custom rear shocks from GAZ shocks in the UK.
Also, now that you have a more performance oriented ride height and (assuming) spring rates, you probably want a more performance oriented alignment. Shim the rear to 0° toe instead of the factory specified toe in and the car will feel much more responsive.
I hope you got it aligned anyway. If the car had any negative camber stock in the rear, it will now have additional toe in due to the change in angle of the twist beam.
