YS-1 LSD Trans fuild help ( I know this has been done before )
I saw a post about this acouple of days before and asked a question but now I can't find the old post that someone did. I looked in Hybrid , ALL MOTOR < and now Tech , so I need to know. I have a ys-1 LSD Cable transon my B16. I know sometimes times with cable trans the gears grind and the LSD makes noise. Well someone said to use this stuff called GM Syncro Shift ( or mesh ). I asked if all you do is replace ALL the trans oil with this stuf or just add a Quart of this GM stuff with regular H Manual trans fuild. Thanks like I said I tried looking for the old post before putting this one up but it's either two far back sinc it was on last friday or I'm blind. Thanks
Re: YS-1 LSD Trans fuild help (7PSiEF9ZC)
Yes Drain and replace with syncromesh fluid.
