Would 99 Integra Brakes Fit an EG?
I know a 94-97 integra brake set would swap in an EG. Would a 99 set swap in as well?
Re: Would 99 Integra Brakes Fit an EG? (Fatty_1775)
Yes. They should be identical from 94-01
Re: Would 99 Integra Brakes Fit an EG? (DarkKnight1)
and the front set, do you just swap the fronts? knuckle, calipler etc? there is alot of info for rear but i cant find out if the 99 fronts are compatible with the front of an eg.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fatty_1775 »</TD></TR><TR><TD CLASS="quote">and the front set, do you just swap the fronts? knuckle, calipler etc? there is alot of info for rear but i cant find out if the 99 fronts are compatible with the front of an eg. </TD></TR></TABLE>
I'm 99% sure you need the whole knucke, rotor, caliper. Also, you will need a larger master cylinder than your stock eg one. After I did my swap and without the new MC my brakes were slightly mushy. |
