Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Hybrid / Engine Swaps (https://honda-tech.com/forums/hybrid-engine-swaps-18/)
-   -   Where is my map sensor plug (https://honda-tech.com/forums/hybrid-engine-swaps-18/where-my-map-sensor-plug-860684/)
zlambe May 10, 2004 03:31 PM
The car a 92 vx I am swapping in jdm b16a came complete with full wiring harness but no map sensor or wiring or plug for one. The shock tower harness has four plugs but no plug coming off for the map sensor. Wirng harnesses matched up except that fourth plug. WTF!!!!! Anyone have any ideas. I searched everywhere but cant find anything.
Modified by zlambe at 5:08 PM 5/10/2004
xcchicx May 10, 2004 04:38 PM
Re: Where is my map sensor plug (zlambe)
you might have gotton the wrong wiring harness. it might be pre-obd that you were given to use. my friend had the same problem and ended up just using the old wiring harness.
zlambe May 10, 2004 05:22 PM
Re: Where is my map sensor plug (xcchicx)
The wiring harness that came with the motor is the right one its the one on the car that is different. I guess i will have to use the vx wiring harness . Anyone else have any ideas
