Where is the Electrical load detector sensor?
I'm throwing this code and need to find the sensor. Where is it??
I hvae a PR3 ECU, jdm b16a motor with hyrdo tranny. Just got the clutch replaced and got hte car back and Im throwing this code. Thanks |
Re: Where is the Electrical load detector sensor? (Got Spoool)
the bottum of the fuse box under the hood
Re: Where is the Electrical load detector sensor? (the buddha)
I could be wrong, but I believe it is in the alternator. The alternator should have a plug with 4 wires, and two of them are for the ELD.
9 times outta 10 its NOT the sensor itself (which btw is located under the engine bay fuse box) normally you have a bad ground somewhere. Check all of your 3 grounds (valve cover, tranny, and thermostat).
