GSR ENGINE IN G2 TEG
Old 06-20-2004, 05:26 PM
RACING INTEGRATION's Avatar
Default GSR ENGINE IN G2 TEG
IS THE G3 GSR ENGINE A BOLT IN PIECE?
OR DO I NEED A MOUNT KIT?
CAN I ONLY SWAP IN A G2 GSR ENGINE?
AND WHAT ABOUT THE WIRING FOR VTEC?
DOES ANYBODY KNOW A SITE WHERE I CAN GET INSTRUCTIONS ON HOW TO DO THE WIRING?
Old 06-20-2004, 06:35 PM
VTECVillain's Avatar
Default Re: GSR ENGINE IN G2 TEG (WJT CRX)
B18C1's are a direct bolt in using the 90-93 Integra mounts and brackets. You'll need to use a cable B series tranny, LS ratio won't be as good as a GSR YS1 or JDM tranny. 90-91 will require more wiring as you should be converting to OBD1. 92-93's are OBD1 so a 94-95 P72 ECU will plug in. You'll need to add wiring for the usual VTEC solenoid, pressure switch, knock sensor and IAB.
Civic Racer X 7
06-05-2014 07:03 AM
Terror_Teg
05-05-2006 06:17 AM
GS-Rcivic
12-20-2003 06:45 AM
3minburnout
09-16-2003 08:30 PM
Quick Reply: GSR ENGINE IN G2 TEG
