vtec , knock sensor wiring problem
b16a2 into a eg 94 hatch cx... where exactly on the engine are the wires i need to connect.... (vtec, vtec pressure and knock)
Re: vtec , knock sensor wiring problem (yellowmonkeyboy)
VTEC and VTEC pressure are right in front of the distributor. The knock is on the back in the middle just above the oil filter.
Re: vtec , knock sensor wiring problem (VTECVillain)
what happens when you dont connect the knock sensor?
Re: vtec , knock sensor wiring problem (spooned-ek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spooned-ek »</TD></TR><TR><TD CLASS="quote">what happens when you dont connect the knock sensor?
</TD></TR></TABLE> You'll be looking at a DTC sheet... https://honda-tech.com/forums/images...s/emsmilep.gif |
Re: vtec , knock sensor wiring problem (JV)
DTC?
DTC sheet please explain
trouble codes your computer throws when the engine or sensor is working properly.
| All times are GMT -8. The time now is 09:30 AM. |
