Troubleshooting: B18C5 Swap questions
#26
Re: Troubleshooting: B18C5 Swap questions
UPDATE:
Checked the wiring... loose connection. cleaned it up and re wired. rpm idle dropped from 1.7 rpm to .9 rpm idle. CEL went away but came back again with CEL code 14 for IACV. I tried cleaning IACV recently. might be time for a new one??
it was a 1 pin plug btw...
1 wire sensor is the Engine Coolant Temperature sending unit for the gauge cluster. Good deal though.
#27
Also purchased brand new oem hoses...
Ill post again once done
Thanks again!!
#28
Code 41 Oxygen Sensor Heater Circuit Loose Wiring.
I replaced the O2 sensor with Bosche last month. Throwing this code...
Might be a dud?
otherwise, engine turns on perfect and low idle.
Might be a dud?
Meyerwi
12-03-2013 07:39 PM
LAO
10-12-2007 04:01 PM
