tried other forums: b series question - jdm s1 tranny with ats final drive and ats lsd?
Sorry for the repost, but I need to make this work! http://images.zeroforum.com/smile/emsad.gif
Suppose this was all mated to a jdm itr motor in a gutted crx... jdm s1 tranny... (ratios are the same as usdm itr/ jdm 96 spec itr): Now just suppose you had everything, but the final drive (ats 4.9) pinion didn't work - as it was for a 98 spec itr... Which final drive (p/n) should I order from ATS (4.929 ratio of course)... The ATS LSD is for a 98 spec itr too... Dammit, we're soooooo close!!! |
Re: tried other forums: b series question - jdm s1 tranny with ats final drive and ats lsd? (Black R
Sorry for the repost, but I need to make this work! http://images.zeroforum.com/smile/emsad.gif Suppose this was all mated to a jdm itr motor in a gutted crx... jdm s1 tranny... (ratios are the same as usdm itr/ jdm 96 spec itr): Now just suppose you had everything, but the final drive (ats 4.9) pinion didn't work - as it was for a 98 spec itr... Which final drive (p/n) should I order from ATS (4.929 ratio of course)... The ATS LSD is for a 98 spec itr too... Dammit, we're soooooo close!!! but what I mention is that you'll HAVE to use a ITR/CTR ring gear, because its made to be used in accordance with an actual ITR/CTR LSD and 4.785 FD kit, while the S1 ring is not.....because its too small in diameter and also, the inside of the S1 tranny bellhousing around the ring gear would need to be modified in order to allow the ITR/CTR ring gear to fit. You should hit up JDM DAVE on this subject......supposedly he has experience with fitting an ITR/CTR LSD and/or 4.785FD into a cable B-series transmission. |
the inside of the S1 tranny bellhousing around the ring gear would need to be modified in order to allow the ITR/CTR ring gear to fit. Ken you know this already. http://images.zeroforum.com/smile/emhammer.gif Blank had to modify his Cable tranny to get the ITR LSD to fit...remember? Talk to him. I'm ready to swap that shiet already!!!!! http://images.zeroforum.com/smile/emwink.gif |
Ken you know this already. http://images.zeroforum.com/smile/emhammer.gif Blank had to modify his Cable tranny to get the ITR LSD to fit...remember? Talk to him. I'm ready to swap that shiet already!!!!! http://images.zeroforum.com/smile/emwink.gif http://images.zeroforum.com/smile/emhammer.gif http://images.zeroforum.com/smile/emhammer.gif http://images.zeroforum.com/smile/emhammer.gif on you bro! BLANK is the one who can't figure it out... I'm trying to help HIM here!!! http://images.zeroforum.com/smile/emsmilep.gif Katman, I got your IM and THANKS AGAIN!!! We got the 98 spec ATS LSD and ATS 4.929 final drive ring gear to work... but the s1 gears won't fit on the SHAFT!!! http://images.zeroforum.com/smile/emsad.gif So either we now need some b16 gears (from a 99-00 si) or.....? DOH!!! http://images.zeroforum.com/smile/emsad.gifhttp://images.zeroforum.com/smile/emsad.gifhttp://images.zeroforum.com/smile/emsad.gif |
Ahh, Blank is stumpted....no comment. http://images.zeroforum.com/smile/emsmilep.gif
.....thanks to katman I think we have this figured out:
usdm 92-93 gsr tranny 98 spec ats lsd 98 spec atl 4.929 final drive http://images.zeroforum.com/smile/emthup.gif |
