Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Hybrid / Engine Swaps (https://honda-tech.com/forums/hybrid-engine-swaps-18/)
-   -   transmission cases (https://honda-tech.com/forums/hybrid-engine-swaps-18/transmission-cases-1467303/)
ED9man Dec 18, 2005 06:46 PM
transmission cases
What other B-series cable transmissions cases (not the clutch housing, the other part), if any are compatible with a 92 GS-R transmission. I tweaked an orifice for the shift rod inside the transmission. I had a transmission shop make shims to correct it, but it doesn't work the best. It is really hard to find one of these transmissions and the other cable ones are really easy to find and cheap so it would be nice if I could get away with a case out of a non-VTEC integra. Let me know if it's possible. Thanks.
ED9man Dec 18, 2005 06:51 PM
Re: transmission cases (ED9man)
I just looked up the part numbers for a 92 GS-R and a 92 GS and they match meaning they are the same part and should work right?
Honda Bull Dec 18, 2005 08:43 PM
If it's the same part number then yes.
The 92 GSR tranny should just be a B16 tranny... which has typically shared the same parts as the LS (B18A/B) trannies. But again... if the part numbers are the same then you're golden. Good luck... trannies are a pain.
