Throwing Codes!!!
92 ls swap in 90 Dx hatch...
throwing codes 4-crank position 7-TPS 14-EACV(idle air control valve) 16-fuel injectors how the HELL do i fix this??? |
Re: Throwing Codes!!! (VTEC93hatch)
dude id love to help but its so hard with out being there and looking for myself
Re: Throwing Codes!!! (Timmay)
https://honda-tech.com/forums/images/smilies/mad.gif i don't know what to do......
did you convert to mfpi?
Re: Throwing Codes!!! (poison)
so hard to tell someone how to check shit, if i was there i could look at it and tell you the problem, just trace all your wires, check all connections, make sure everything is plugged whre its supposed to be, etc..
good luck |
ok...
no more 7,14,16 codes...just CODE 4...crank position sensor.... but the thing is...it runs like a raped ape for alittle...then check engine light comes on....and it runs like shit...breaks up at anything over half throttle....and the ecu flashes 4 quick flashes...maybe the crank position sensor is going bad???? tell me what you guys think................. https://honda-tech.com/forums/images/smilies/emthup.gif over all...that thing rips!!! 1st gear...starting off....break the tires loose around 5 grand...2nd and 3rd rip ass... poison and timmay...i wish i was out west...better than her...FUCKIN SNOW!!! thanks guys!!! https://honda-tech.com/forums/images.../h-emblem4.gif |
help!!!
well did you wire the CKP sensor to the ecu?
no? theres your problem. https://honda-tech.com/forums/images/smilies/emwink.gif |
Re: Throwing Codes!!! (Kamin)
CKP sensor? wtf is that? lemme know...
what color are the wires...and what pinouts do they go to...??? where on the dizzy do the wires from ecu go??? [Modified by VTEC93hatch, 4:45 PM 3/10/2003] |
[QUOTE]CKP sensor? wtf is that? lemme know...
what color are the wires...and what pinouts do they go to...??? where on the dizzy do the wires from ecu go??? QUOTE] CKP = Crank position sensor (just like I told yah on AIM https://honda-tech.com/forums/images...s/emsmilep.gif ) CKP-M = White wire on distributor - goes to B12 on the ECU CKP-P = Orange wire on distributor - goes to B11 on the ECU Make sure those are wired up properly. |
Re: Throwing Codes!!! (Newman)
FINALLY!!!
well i got it running right...finally!!! VtecVillian came up with this: use shielded wire for the CKP wires from the dizzy to the ecu...i did that...grounded the center wire...and now it runs perfect..NO codes...and No spittin and sputterin....thanks everyone for your help!!! https://honda-tech.com/forums/images/smilies/emthup.gif now i just gotta put the fucker back together.... |
| All times are GMT -8. The time now is 06:51 AM. |
