S2000 Cluster Swap Wiring Guide
#53
Re: (rez650crx)
Dave does not answer or return anyone's phone calls or money!
I want a refund and he ignores me. I have been waiting since last summer for the convertor!
Just refund my money
#55
Re: (alscrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alscrx »</TD></TR><TR><TD CLASS="quote">Dave does not answer or return anyone's phone calls or money!
Just refund my money </TD></TR></TABLE>
I have been waiting since march!!!
#56
Re: (LD-rhdEG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LD-rhdEG6 »</TD></TR><TR><TD CLASS="quote">awesome write up everything almost works on mine!
Modified by LD-rhdEG6 at 1:13 PM 4/8/2008</TD></TR></TABLE>
hey bro, where did you get the cover for your custer? im trying to find one for my EG6 and to no avail! If you make them, let me know and id happily purchase one from you! I live in Japan (u.s. army stationed here) and can't get these sorts of things fabricated for me due to my lack of Nihon-go (japanese)
#60
Re: (Sp00nFed EM1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sp00nFed EM1 »</TD></TR><TR><TD CLASS="quote">the link to the other thread is down, anyone know another good write up for an ek?</TD></TR></TABLE>
i need too or at least the schematic for the s2000 cluster harness
#61
Re: (thareddb)
just finish wiring the cluster into my boy ek just need the 2 converters everything else works
Modified by pblockfinest at 1:28 PM 8/2/2008
#65
Re: S2000 Cluster Swap Wiring Guide
just finishing up mine.. !!!
whats the ECT on the temp guage part...
and. anyone find a solution for kswapped cars? im not sure if i read someones post correctly.. but it seemd like he was saying i can wire the VSS of a 05 k serires trannie to the cluster, and the cluster to the ecu... by which the cluster does a speed conversion for the ecu(kpro) instead of getting the speed converter box?>?
can some one clarify?
#66
Does anyone know what the pulse rate is for the S2000 factory VSS input vs speed? I'm curious what it is expecting, which should be fairly simple to figure out if someone knows the tooth count on the trigger wheel input for the sensor and the corresponding gear ratios from the engine to that point. I would then be able to cross reference that expected value to what the output of my own sensor would be at that same engine rpm/real world speed.
#68
Re: (LD-rhdEG6)
#70
When wiring it up, What is the easiest way to do it? like, de-pin or what, sorry put that confuses the **** out of me ha
Do you take off the Ek plugs and leave only the AP1 cluster plugs?
thanks
thanks
#71
Location: Where the shooting range is on the streets of LA, CA.
suscribed does anyone know if usdm or jdm s2k clusters matter for this project?
#73
ok so u color match the wires from the s2k cluster pigtails to the wires from your car that connect to your stock cluster right? so where do you hook up the vss and ect converters at?? or how?? any help oh btw i have a dc2 obd1
