quick tranny gear ratio q's h22 swap civic
i have a h22 with a p2u5, in my civic, the tranny apparently is from accord. how much time will i cut off the quarter if i swapped in a jdm h22 tranny with lsd (M2B4), hers a link, i dont know how to calculate this
, also could i use the k20 rsx-s tranny? http://www.accordinglydone.com/data/ click on transmissions. or if you did this first hand how much time did you shave off |
Re: quick tranny gear ratio q's h22 swap civic (djsire)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djsire »</TD></TR><TR><TD CLASS="quote">i have a h22 with a p2u5, in my civic, the tranny apparently is from accord. how much time will i cut off the quarter if i swapped in a jdm h22 tranny with lsd (M2B4), hers a link, i dont know how to calculate this
, also could i use the k20 rsx-s tranny? http://www.accordinglydone.com/data/ click on transmissions. or if you did this first hand how much time did you shave off </TD></TR></TABLE> K motors spin opposite as a H/B/D. Only F or H trannies bolt up to the H without an adpater plate. |
