Purge control valve
Does anyone know how to wire the purge control valve?? I have a 95 LS with a 93 GSR motor. The purge control valve on the 93 gsr is not connected to the main wire harness. It's got four wires(90-93 integra have two purge control valve, 94-00 have one purge control valve) and is attach to the car frame. Any help will gradly appreciate!!!
Modified by B18gsrz at 7:38 PM 12/5/2005 |
Re: Purge control valve (B18gsrz)
Well basically you're staying obd1 anyway, right? Either use the LS's harness and add a wire for the vtec solenoid, or get an obd1 gsr harness. Then just use the egr purge valve from the LS and plug it in.
| All times are GMT -8. The time now is 11:41 PM. |
