Re: (dragline)
Okay that makes sense to me, so if you could give me a better sense or directions on what stays and what needs to go and what needs to be modified...Like to ask first before doing...
Re: (ExplicitSpeed360)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ExplicitSpeed360 »</TD></TR><TR><TD CLASS="quote">Okay that makes sense to me, so if you could give me a better sense or directions on what stays and what needs to go and what needs to be modified...Like to ask first before doing...</TD></TR></TABLE>
I pm'ed you back, but the only thing that has to be modified is the holding tab. |
Re: (dragline)
Thanks dragline I appreciate it alot! I got it all hooked up and sure enough a night and day difference it doesnt cut off at 6500 goes to 8k with a breeze I knew I had a spoon chip ecu. Vtec kicks in at 5k. It's a total different beast. Losing traction in any gear. so my 15.2 was with no vtec. lol It has to be atleast a second or more faster!!! Pulls like a motha!!! time for a tach light cuz the thing has no signs of stoping past 7300 https://honda-tech.com/forums/images/smilies/emwink.gif
I am taking the car to the track today again with vtec this time https://honda-tech.com/forums/images...es/emsmile.gif I will post results and impressions.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ExplicitSpeed360 »</TD></TR><TR><TD CLASS="quote">I am taking the car to the track today again with vtec this time https://honda-tech.com/forums/images...es/emsmile.gif I will post results and impressions. </TD></TR></TABLE>
Soooo ..how'd you do? I'm taking bets on 13.7 @ 102 https://honda-tech.com/forums/images/smilies/emwink.gif |
Re: (WhiteSol)
Here is the results I was pretty happy with the outcome for the first time at the track with VTEEEEC! Definetly need some stickier tires my shitty hankooks aren't helpin especially on my 60'. My R/T sucks too. My best run I ran a built/aftermarket STI and beat him by a nose. He definetly had me off the line obviously by bout 4 cars. I remind you this car is untuned and running a p13 ecu. I was shifting on the last run 7-7500 each gear. Every run so far I have gotten quicker and quicker the stoping point is close by high 13s woulda been achievable last night if I had another run. This is just a beginning.
http://www.we-todd-did-racing.com/we...ZkMzF5NTQx.jpg Elevation 1320 above R/T .869 shitty! 60' 2.363 definetly shitty! need to hit 4500 off the line next time 330 6.162 1/8 9.208 MPH 81.32 1000 11.826 1/4 14.00 MPH 101.89 I did beat Hasports H22 crx by a tenth... Modified by ExplicitSpeed360 at 11:39 AM 9/1/2005 Modified by ExplicitSpeed360 at 11:40 AM 9/1/2005 Modified by ExplicitSpeed360 at 11:51 AM 9/1/2005 Modified by ExplicitSpeed360 at 11:51 AM 9/1/2005 |
Re: (KEVlN)
the ETA is there. You just need traction. you will get into mid 13's easy.
Re: (91' LS-VTEC)
stuff that dont help much stock header and downpipe and 2" exhaust with cherry bomb (short-term use)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ExplicitSpeed360 »</TD></TR><TR><TD CLASS="quote">stuff that dont help much stock header and downpipe and 2" exhaust with cherry bomb (short-term use)</TD></TR></TABLE>
Ya that 2" has to go, I would unbolt the exhaust from the downpipe at the track. |
Your trap speed is screamin high 13's easy. I ran 1mph slower and hit 13.8 with my h coupe. So im sure you're well on your way. I had some beat up slicks though and was hittin 2.0 60's.
Good job though! Keep it up! https://honda-tech.com/forums/images/smilies/emthup.gif |
Re: (dragline)
I also had a re-occuring CEL problem that effected my idle at the track on my 14.0 run my idle would pulsate 500 rpm it also effected throttle response from 1-3k rpm. I since found the problem it was the O ring in the IACV it was leaking air apperantely. The throttle response is definetly improved under 5k rpm. So another track pass is in deed needed in the next few weeks. I will also take the exhaust off too! Shift light and VAFC is definetly needed in the near future. https://honda-tech.com/forums/images/smilies/emthup.gif
i would think you could do mid 13's easily. being that most eg/ej h22 swapped cars run high 13's all day. lack of traction may be it. but r/t has nothing to do with your overall time. https://honda-tech.com/forums/images/smilies/emwink.gif
Re: (boostedej1)
damn just saw the right up awesome numbers man there is one h22 crx in tucson it was put together by collectiveracing.net many pictures of that swap on the website.
he has issues with the traction bar setups always breaking... ill bookmark this too hear more goodluck https://honda-tech.com/forums/images/smilies/emthup.gif |
Re: (N_A_is_best)
awesome job.. just read the whole thing and saw the pics. now i feel inspired to trash my b16 for a h22 https://honda-tech.com/forums/images...s/emsmilep.gif
Re: (N_A_is_best)
a traction bar is pretty straight forward. I even run my tabs for the rods underneatch instead of infront of the bar. I have no problems and love it, very effective keeps nose down and straight! Only problems I think you could have would be if the welds arent good and if the rods them selves are too tight etc. Thanks for the comments! https://honda-tech.com/forums/images/smilies/emthup.gif
Comments on the collective racing h22 crx: They didnt have to cut out the driver side chassis mount the could of used it. But it was a PR kit I believe not a custom. My mount kit you can keep the driver side chassis mount and do none to minimal cutting on the passenger side wheel well opening from the inside of the wheel well. Also I am producing the mount kit for the public EF 88-91 Civic/Crx h22a mount kit! |
Re: Project Log of 90 CRX HF with a JDM h22a swap!!! 10 lbs of shit into a 5 lb bag!!! (ExplicitSpee
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ExplicitSpeed360 »</TD></TR><TR><TD CLASS="quote">The project is to fit 10 lbs of shit into a 5 lb bag..</TD></TR></TABLE>
So then My 85 crx would be 20 lbs of shit into a 5lb bag... https://honda-tech.com/forums/images...s/emsmilep.gif http://www.we-todd-did-racing.com/we...ZkMzF5NTQx.jpg |
LOL that is TIGHT https://honda-tech.com/forums/images/smilies/emthup.gif |
no lol i think its still 10 lbs of shit, but a 3 lb bag
updates? any times yet?
Re: (higgunscrx)
tracks closed for year at pacific raceway and i should be able to go to either 23,28 to bremerton for last of the test n tune sessions...
Re: (dragline)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dragline »</TD></TR><TR><TD CLASS="quote">You should use the crx harness and add and extend what plugs you need. </TD></TR></TABLE>
That is correct. Always try to use the harness that comes with the chassis. ----- I must have missed this threa d.. dont go to the EF forum enough! anyway - good job with the swap! https://honda-tech.com/forums/images/smilies/emthup.gif |
Re: (2point2)
bringing this puppy back just b/c i want to know if this First time H swap really put it down. Any time there dude? I am really impressed with how well you did(if i read right) for your first time swapping the H series. I was 18 when i did my b16 HF swap, and i had problems just handling that....I applaud you bro. you make me wanna go expletive with more of my cars.....Too bad i don't have money...hahaha
Pics/Vids/Times. Anything? https://honda-tech.com/forums/images/smilies/emthup.gif |
Re: (WrongWD)
haha so funny damn nice build man keep it up!
Re: (repn a lude)
HaHa who brought this back from the dead???? 1/7/07
No accurate times of the car yet, last spring I was able to manage constant 106 mph trap speed, I had too many issues with the car at the time last year, vafc was glitching with my vtec, so my vtec would have a very noticable delay and then a sudden oomppph in power which might of played havik on the old engine and of course ET's showed something wrong 14.0. I didn't have an exhaust as well 2.5" no muffler, bogged off the line too much...the engine was way too rich with my jdm spoon chipped p13... The engine has been since rebuilt (stock internals still) and has about 3k miles on it, night and day difference from switching ecu's and using Crome, p28 crome tuned on the dyno it made 200 whp and 168 ft lbs of torque...a pick up of 15 whp and 11 ft lbs of torque from last go around...with just I/H/E Our Own H22A header 2.5" collector...2.5 mandrel bent exhaust system...I will be heading up to the track the begining of next month to try and get her dialed in ONCE AGAIN...with street tires...I predict a 12 second pass this year with street tires... A customer's car nottin special recenty went 13.3 @ 104 worn bald street tires, jdm h22a, shitty ebay header, intake, 2 1/4" exhaust, p13 ecu, I believe his engine was putting down 160-170 whp. So makes me believe a 12 second pass may be achievable this year...the car weighs in this year at 2050 lbs... https://honda-tech.com/forums/images/smilies/emthup.gif |
| All times are GMT -8. The time now is 07:25 PM. |
