problem GSR swap on a 1994 civic hit the gas and it wants to stall
i swapped a obd1 gsr motor into my civic ...
car starts fine idle is fine timing is perfect only problem that i have is that when i hit the gas the rpms go down then like on na delay they catch back up and rev up like 800rpms hit the gas 500rpms 500rpms then will jump to 2000rpms hard to explain best way is that it delays b4 revving up any help would and id be greatful |
Re: problem GSR swap on a 1994 civic hit the gas and it wants to stall (95BlkGSR)
did you replace anything when you put it in? Timing belt, distributor cap and rotor, etc?
Re: problem GSR swap on a 1994 civic hit the gas and it wants to stall (HondaPartsHero)
we solved it the IAC needed adjusted
