please help me swap!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
i have a b16 sirII swap coming here in an hour it comes with the 2 main motor mounts, and a shift linkage... it is going in to 95 civic ex, what rear mount do i need , or can i use the stock mount and just change the bracket??? also the shift linkage that is coming with the motor should work right? i have everything else just no mounts the stock motor in my car was the d16z6 what do i need please help,
anybody?
Re: (mattyg1405)
You can use the civics rear bracket and mount, the shiftlinkage is good (provided it came from a civic and not a sol). You will need to get the front two torque mounts for the motor, and use yous civics rubber mounts that bolt to the underside of the chassis in front of the motor.
ok so my stock d16z6 rear bracket & mount will work with the b16?
??? hurry lol i am about to leave to get what i need
