Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Hybrid / Engine Swaps (https://honda-tech.com/forums/hybrid-engine-swaps-18/)
-   -   obd1 Dizzy obd2a harness problems (https://honda-tech.com/forums/hybrid-engine-swaps-18/obd1-dizzy-obd2a-harness-problems-1454726/)
DirtRider Dec 5, 2005 06:17 PM
Hey guys. done a search.. tryin to figure this thing out.. ive got a JDM b16a gen2 swap in my EK (98) .. im runnin my stock harness right now.. i have a obd2-obd1 jumper for the ecu.. changed injectors bla bla bla.. i need to swap plugs from obd2 to the obd1 plug for my dizzy.. anyone have a wire diagram to swap the dizzy plug? any help would be VERY much appreciated.
thnx in advance...
Ash
Ax3l Dec 5, 2005 10:26 PM
I'm doing the same thing...
My thread - https://honda-tech.com/zerothread?id=1448353
markturbo Dec 6, 2005 03:21 AM
Re: (Ax3l)
I think this is what you're looking for...
http://img235.imageshack.us/my...g.jpg
Modified by markturbo at 7:21 AM 12/6/2005
Ax3l Dec 6, 2005 05:02 AM
Re: (markturbo)
That link is no good... https://honda-tech.com/forums/images...s/emthdown.gif
Need the whole url... https://honda-tech.com/forums/images/smilies/emwink.gif
markturbo Dec 6, 2005 06:32 AM
Re: (Ax3l)
Should work now
DirtRider Dec 6, 2005 06:45 AM
Re: (markturbo)
i actualy found that last night.. its everything i need for my motor(obd1) side of life.. however i think i still need a diff. diagram for obd2a (harness, d16) side.. i tihnk wire codes are dif. b/d 16 are they not..
Katman Dec 7, 2005 12:28 PM
all you gots to do is color match the wiring from the OBD1 dizzy to your OBD2 dizzy and you should be set.
Also, this there's word that you can completely swap the interals of your OBD2 dizzy into the OBD1 dizzy.....all so you don't have to cut & splice or depin/repin the OBD2 plugs to the OBD1 dizzy.
