O2 sensor problem
just wondering if anybody knows any steps to take to try to get rid of my ECU code 01 from my b16a....i almost always get it when the motor is cold and first started, usually when it warms up i can turn off the key and it resets, but usually will came back when i'm idling, i got new O2 sensors with my swap and have always had this trouble http://images.zeroforum.com/smile/emdgust.gif
Re: O2 sensor problem (KY88CivicSiR)
Try a new O2 sensor..you say you got a new O2 sensor with the swap..nut new stuff is defective sometimes.
Re: O2 sensor problem (CivicLS)
yeah, i'm pretty sure they are hooked up right, i just wonder if not using shielded cable would cause them to be erratic....the guy who did my swap used regular wire to hook them up....
| All times are GMT -8. The time now is 07:01 AM. |
