Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Hybrid / Engine Swaps (https://honda-tech.com/forums/hybrid-engine-swaps-18/)
-   -   NOS HELP!!??!!! (https://honda-tech.com/forums/hybrid-engine-swaps-18/nos-help-83237/)
scrubachu Oct 28, 2001 06:52 PM
NOS HELP!!??!!!
ran a 55 shot of NOS on a zex kit, for my 93 accord with h22 motor. i have msd ignition, pplugs, purge kit, and everything else for it. Problem is, i ran the NOS for the first time, and the heaflights dimmed. Now they wont come back to normal, the lights come on, but there is barely any light coming from them. i checked all the fusees, and relays, and still the same. parking lights work fine, and high beams are fine too. anyone have any ideas??????
Jared Oct 28, 2001 07:12 PM
Re: NOS HELP!!??!!! (scrubachu)
Fuck, how many forums did you post this in? I see it everywhere. Come on now, this is excessive.
Variance-EJ-6 Oct 28, 2001 07:59 PM
Re: NOS HELP!!??!!! (Jared)
well he needs to know......I couldnt tell you what needs to be done to it though.....replace the bulbs, you might have burned out some filament....late
88_SC_CRX_Si Oct 29, 2001 09:57 AM
Sounds like something went wrong with your wiring, when you hooked the NOS up. Go back over every little thing you did to it. That is if noone has already mentioned this..... hehehehe
scrubachu Oct 29, 2001 11:47 AM
Re: NOS HELP!!??!!! (88_SC_CRX_Si)
replaced the bulbs, still nothing. checked the wiring also, still nothing. any other suggestions?
Variance-EJ-6 Oct 29, 2001 12:12 PM
The ZEX kit has its own module, its gotta be something either with that, or you burnt up one of your light relays....there are two i think in a accord....check your manual, find your relays and check them....later
Mista Bone Oct 31, 2001 01:34 PM
Where did you hook up the power for the ZEX at? I went straught to the battery and used 14 gauge wire with a 20 amp fuse.
18 gauge wire will go up in smoke. I know, mine did!
