Need some Specs please!
Ok i need some specifications on transmissions and engines.
Which way does the F20c rotate clockwise or counter clockwise? Same with an LS Also what is the diameter of the F20 transmission case same for LS transmission |
Re: Need some Specs please! (07civicSI)
I also need to know the ID of the B18A1 tranny shaft
And the OD of the F20 tranny shaft Plus the number of splines on each! |
Never mind i found out that the 2 turn separate directions.
