Need help: Throwing o2 sensor CEL code!!!
I have a 95 gsr in my 92 hatch and have been throwing a code 1. At the moment, I don't have the space/resources to jack the car up and check under to see if the o2 sensor is disconnected or something. I'd probably be able to do so in 2 weeks. Would it be safe driving the car around meanwhile?
Any tips as to how I should diagnose the prob? Any way to figure out whether it's a faulty sensor or connection? How much $$$ do o2 sensors usually cost? Thanks guys. BTW, I did order a helms manual a couple of days ago cuz I thought it might be a great help. -Rod |
Re: Need help: Throwing o2 sensor CEL code!!! (RK)
good move with the helms
and well if the o2 sensor is fried, your gas mileage will go straight to shit. they run from 75$ for a bosch replacment to i think 200 for a honda one. mine went out during my swap (had to use an impact gun to remove it from stock header, hehehe) im using a bosch replacment, works fine. |
Re: Need help: Throwing o2 sensor CEL code!!! (KAMiN)
Thanks for the reply man. Yea, I noticed that my gas mileage has suffered a bit. Can I get a bosch replacement @ a local pep boys or something?
-Rod |
I try and stick with OEM parts...so thats what I am going to recommend for you, if yours is indeed bad. However, if you go to the dealer....your a fool. Order from somewhere off the net, like HParts.com. There are tons of places out there to get an O2 for less than 200 bills.
Re: Need help: Throwing o2 sensor CEL code!!! (EE_Chris)
I just emailed sohfast.com for more info on the o2 sensors. He's selling for $70..but dunno if it's new/used
-rod |
| All times are GMT -8. The time now is 02:37 PM. |
