Need help 1995 Civic Hatchback SOHC
Any ideas of what engine I could possibly swap to?? Is there any way to change my stock engine to a DOHC without having to swap out the whole engine?
Re: Need help 1995 Civic Hatchback SOHC (PwErDbYGTR)
youd have to get a whole new engine. get a good sohc vtec head, a good cam, port and polished head and intake manifold with a big bore TB. Sleeve it bore it out and that SOHC would be quick as hell.
Re: Need help 1995 Civic Hatchback SOHC (ALLmotorCRX)
the quick way to make horse power is to swap the motor good an cheap swap for ya would be a b18b1 with a hydro tranie it would make 143hp and the botors are cheap. and by the way you should not have to sleave a motor if your not turbo and by over boring the motor your not gona see big gains onles you do it all properly with rods,crank and pistons to complete a stroker kit https://honda-tech.com/forums/images.../h-emblem4.gif
Thank you for all your help, any other suggestions???
What kind of car do you have? A mini-me swap will be a waste unless you have a VX.
Staying SOHC for sure?.....get a D16Z6 swap. There dirt cheap. Spade and Mista Bone can also big a huge help around here for SOHC. http://www.hmotorsonline.com http://www.nippon-motors.com http://www.SOHfast.com |
