My H22 swap into EF using Hasport mounts
I'm now selling this car, & possibly part it out. Link is in my sig
I wasn't able to find many super informative pics of this swap when I was preparing for it so I figured I'll post my progress. Please no comments about the black paint or other less than show quality stuff, I'm a function over form type of guy. Anyways, I'm doing the finishing touches & waiting for the correct axles to be sent to me (they sent me some 'B' series axles), so it's not on the streets yet. The set up is as follows: H23A Euro Accord Block (Oops guess I should've titled the thread "H23 vtec swap") Ported H22 head with Crower Stage 3's & flat valves Ported Intake manifold (by Blacktrax) I have an extra ported IAB plate on it to iincrease plenum volume which does make the manifold sit a little taller, so keep that in mind as you look at the pics. STR 68mm T-body Hytech Header 2 1/2" exhaust Rywire harness Explicit Speed traction bar AEM EMS tuning Hasport mounts & stage 2 axles I'm hoping to get at least 215 NA whp in a sub 2000 lb car = wheeee!! Empty engine bay & banged up firewall (the firewall really only needs banging near the TPS, the Brake booster inlet, & the IAT sensor (bang the booster) https://img57.imageshack.us/img57/5317/dscf00021fa.jpg New trans mount & cut framerail. It turns out I unfortunately removed more framerail than is needed so do not follow my example. Keep checking out the Hasport site they will get better instructions & pics up soon. https://img382.imageshack.us/img382/...scf00030xi.jpg The engine is in!!! https://img382.imageshack.us/img382/...scf00096hr.jpg Radiator issues. I didn't think there would be any because the Hasport instructions say "put the radiator back in" with no mention of clearance problems so I thought my half radiator & slim fan would fit fine. Not the case. I've been doing some cutting & drilling to get the radiator positioned as you see it now. https://img382.imageshack.us/img382/612/dscf00113da.jpg TPS clearance. My manifold is taller because of the extra IAB plate. Other swaps won't hit the seam like I did, but still require a good sized dent for the TPS sensor. https://img57.imageshack.us/img57/7027/dscf00134au.jpg Brake Booster dent https://img382.imageshack.us/img382/936/dscf00150hg.jpg Hole for the shift cables https://img57.imageshack.us/img57/438/dscf00179dx.jpg NEW PICS: Here's the hood clearance issues. It is not interfering with the skeleton (ie making it so cutting out some skeleton would resolve it). The valve cover is hitting the thinner, less structural portion of the hood just inside of the skeleton. The only solution is space it up or buy an SiR hood that I have not budgeted for. Anyone want to donate to the help me buy a SiR carbon fiber hood fund https://honda-tech.com/forums/images...s/emsmilep.gif? https://img271.imageshack.us/img271/...scf00127ez.jpg https://img271.imageshack.us/img271/...scf00056hx.jpg UPDATE (6/10/06): Here's how I spaced up the hood for now on the sides & the front. Basically needs around an inch on the rear & 1/4" up front. https://img53.imageshack.us/img53/2819/dscf00046vw.jpg https://img53.imageshack.us/img53/3300/dscf00054yv.jpg The hood sits crooked diagonally at the moment. The front passenger side looking stock then it slopes up as it goes towards the rear & towards the driver's side. Don't laugh at my beater. I'll replace the fender's someday. Those awesome & rare 15" Volk GRN's on my car are for sale. Hit me up if you're interested. https://img130.imageshack.us/img130/...scf00059ab.jpg Here's the ground clearance on stock suspension. I'll finish wrapping the Thermotec stuff next week, but have to add a little for now because the header was designed for an OEM pan, but just touches the Moroso pan because it has a thicker flange. If you look closely towards that back of the car you can see how I had my exhaust routed for minimal back pressure (3 20° bends instead of 4 90° bends) https://honda-tech.com/forums/images/smilies/emwink.gif https://img130.imageshack.us/img130/...scf00026if.jpg Edit 6/18: I'm still tuning it but the power is certainly there. Creamed an RSX Type S last night. Anyways, the swap is done & I'm happy with everything except for the hood. I've been able to straighten it out & get it off of the valve cover with the use of some hood pins. Here are some pics of the final result w/ the Fiberimages hood that does clear the engine. https://img213.imageshack.us/img213/...ssidesmul1.png https://img175.imageshack.us/img175/2346/engine1za2.jpg Modified by 2lude4u at 11:35 AM 10/17/2006 |
Re: My H22 swap into EF using Hasport mounts (2lude4u)
Explicit Speed Performance EF H22A traction bar system https://honda-tech.com/forums/images/smilies/emthup.gif
http://www.ExplicitSpeedPerformance.net Get rid of the IAT sensor near the brake booster and get a 96+ civic IAT that is in the intake tube and wire it in and extend the wires back to the tube or take out wires out of the loom back. Send us some good pictures of the traction bar installed... https://honda-tech.com/forums/images/smilies/emthup.gif How is the clearance between our radius rods and the Hasports kit, especially on the driver side from crank pulley? I can't tell from the pictures, Do you have about 3/8-1/2" clearance between closest point of the engine to firewall clearance for when the engine moves and you dont knock your firewall every time you get on it? Modified by ExplicitSpeed360 at 3:05 PM 6/1/2006 |
that engine is way to heavy for a CRX! https://honda-tech.com/forums/images...s/emthdown.gif
Re: (2point2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2point2 »</TD></TR><TR><TD CLASS="quote">that engine is way to heavy for a CRX! https://honda-tech.com/forums/images...s/emthdown.gif</TD></TR></TABLE>
HaHa coming from Mr. 2point2 himself. The lightweight flywheel, balance shaft removal, & UR crank pulley should help lighten it up a little bit (around 26 lbs.). Not to mention the lack of AC & my Braille battery placed in the rear. |
Re: (2lude4u)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ExplicitSpeed360 »</TD></TR><TR><TD CLASS="quote">Explicit Speed Performance EF H22A traction bar system
http://www.ExplicitSpeedPerformance.net How is the clearance between our radius rods and the Hasports kit, especially on the driver side from crank pulley? I can't tell from the pictures, Do you have about 3/8-1/2" clearance between closest point of the engine to firewall clearance for when the engine moves and you dont knock your firewall every time you get on it? </TD></TR></TABLE> I haven't put the radius rods in yet (got the bolts from you today https://honda-tech.com/forums/images/smilies/emthup.gif ) but will take some more pics of everything once it's all completed this weekend. The firewall clearance looks good. I may try to get a little more clearance around the TPS because it's still a little too close for comfort. |
Re: (2lude4u)
Anyone ever try ITB's insted of the mani on that crx or ef ?
Re: (DxTrix)
Not that I know of, but I plan on using some when I have the $.
Re: (2lude4u)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2lude4u »</TD></TR><TR><TD CLASS="quote">HaHa coming from Mr. 2point2 himself.
The lightweight flywheel, balance shaft removal, & UR crank pulley should help lighten it up a little bit (around 26 lbs.). Not to mention the lack of AC & my Braille battery placed in the rear.</TD></TR></TABLE> It'll be fine https://honda-tech.com/forums/images/smilies/emthup.gif |
Re: (2point2)
did you get your stock hood to fit? cuz mine looks like the hood is going to have to have the rails cut out. even then i dont know if it will fit... im using the same mounts
Re: (Freeltec)
It looks like the hood is going to need some cutting of the webbing underneath. I spoke with Hasport & they said that they used an SiR style carbon hood which did not require modification. I plan on putting the hood on tomorrow so I'll be finding out if it works well or not.
Re: (2lude4u)
goodluck swaping that manifold...lol
Looks good https://honda-tech.com/forums/images/smilies/emthup.gif |
Re: (2lude4u)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2lude4u »</TD></TR><TR><TD CLASS="quote">It looks like the hood is going to need some cutting of the webbing underneath. I spoke with Hasport & they said that they used an SiR style carbon hood which did not require modification. I plan on putting the hood on tomorrow so I'll be finding out if it works well or not.</TD></TR></TABLE>
You'll need 1 1/4" spacers on the hinges in the rear, and some washers on the latch up front. It will still rub near the dipstick, and there isn't really any "skeleton" to cut away there. |
Re: (alphajesse)
Really? One of the main reasons I went with Hasport & not H2b is because I did not want to be spacing the hood up or any weird stuff like that. I may be in for a rude awakening tomorrow.
Also an update: I did not receive the axles today, so it looks like I won't be able to offically complete this until next week sometime. A few companies dropped the ball with the axle thing & I dont know who is really at fault but I have not really been pleased with Full-Race's lack of customer service. They're nice guys but not on top of things or understand that their mistake should not cost me additional $. |
Re: (alphajesse)
1/4" thick washers????
dang y0. also, i dont get how you can shim the latch because it is mounted underneath that rad support and shimming would make the latch go lower, correct? |
Re: (Freeltec)
1.25" spacers for the rear bolts that attach the hood to the hinge.
Spacers on the latch on the hood, not the part in the rad support. <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2lude4u »</TD></TR><TR><TD CLASS="quote">Really? One of the main reasons I went with Hasport & not H2b is because I did not want to be spacing the hood up or any weird stuff like that. I may be in for a rude awakening tomorrow. Also an update: I did not receive the axles today, so it looks like I won't be able to offically complete this until next week sometime. A few companies dropped the ball with the axle thing & I dont know who is really at fault but I have not really been pleased with Full-Race's lack of customer service. They're nice guys but not on top of things or understand that their mistake should not cost me additional $.</TD></TR></TABLE> Really, you'll need to do this or an SiR hood. I was very impressed with Hasport's inability to tell me anything about how the kit fits over the phone. Also, the D16 alternator does not supply enough juice- it's like driving a car with an underdrive pulley kit. I really should have had my local shop fab their mounts- the engine sits lower and farther back, I could have used the h22 accesories. The only thing this kit has going for it is that the engine sits pretty high, so if you're lowered no worries about the header or oil pan. I guess that's what I get for buying the mounts before they had the instructions posted online. What they have you do with the shifter is pretty crappy too- lots of extra, unneeded bends, and running the cables right by the exhaust. Fortunately my local shop was able to work out something much more elegant, and kept the cables inside the passenger compartment away from the exhaust. |
I was also displeased with the shitty Instructions included with the kid. Hasport doesnt really give much needed info on the net or in the instructions, The kit seem top notch tho in terms of craftmanship no complaints there.
Re: (alphajesse)
BTW, what technique did u use to make the holes to pass through the wall? It doesnt look like a hole saw was used.
Re: (Freeltec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Freeltec »</TD></TR><TR><TD CLASS="quote">I was also displeased with the shitty Instructions included with the kid. Hasport doesnt really give much needed info on the net or in the instructions, The kit seem top notch tho in terms of craftmanship no complaints there.</TD></TR></TABLE>
That's no good I will add our kits come with full detailed instructions and pictures plus I am here to help with the swap from A to Z and not to leave you in the dark. https://honda-tech.com/forums/images/smilies/emthup.gif I am anxious to see how it will perform https://honda-tech.com/forums/images/smilies/emthup.gif |
Re: (ExplicitSpeed360)
I'm STILL waiting on the axles but will post some more pics up soon. I may take my time now & do a few other things before it hits the streets because I may be waiting for a hood now. The OEM Hood does not clear & no amount of cutting besides cutting a hole through the hood is going to fix it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Freeltec »</TD></TR><TR><TD CLASS="quote">BTW, what technique did u use to make the holes to pass through the wall? It doesnt look like a hole saw was used.</TD></TR></TABLE> I bought a 2 1/2" bit, but it required a 1/2" chucked drill (didn't own one at the time, but I do now) so I ended up using a combination of smaller drill bits & a sawzall because I was in a rush to get this done (didn't know I'd be waiting for axles at the time). I cut "tabs" into it then bent them in. Kind of nice in the sense that there isn't a sharp edge of sheet metal for cables to get cut on, but it's not as clean looking? I've cleaned it up & sealed it off now. Modified by 2lude4u at 12:30 PM 6/6/2006 |
Re: (2lude4u)
New pics posted of the hood issues. I took more, but none of them really show what's going on.
Also for explicitspeed your traction bar is clearing the oil pan (Moroso) with around an 1 1/2" of breathing room on the driver's side, so there are no clearance issues. |
Im pissed as hell that the hasport kit wont clear the stock hood, so much for the sleeper look. They could have been more clear about that.
Re: (Freeltec)
Ditto, it's the main reason I bought the kit thinking it would clear the stock hood.
Turns out when hasport fabbed this mount kit they did it on a CRX with a CF SiR style hood, not smart. |
Re: (2lude4u)
An h22 in an EF, I could only imagine.
Re: (2lude4u)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2lude4u »</TD></TR><TR><TD CLASS="quote">Ditto, it's the main reason I bought the kit thinking it would clear the stock hood.
Turns out when hasport fabbed this mount kit they did it on a CRX with a CF SiR style hood, not smart.</TD></TR></TABLE> The way they place the engine, if it sat any lower, the crank pulley would be inside the radius rod. Also, I got a brand-new SiR US hood from VIS this week. Guess what! It STILL RUBS. I needed 3 washers on the latch and on the hinge bolts. Without the spacers it rubbed in the same place that the stock hood was. |
| All times are GMT -8. The time now is 05:46 PM. |
