Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Hybrid / Engine Swaps (https://honda-tech.com/forums/hybrid-engine-swaps-18/)
-   -   mount question (https://honda-tech.com/forums/hybrid-engine-swaps-18/mount-question-937822/)
6shootahorsenamedtrigga Jul 25, 2004 04:42 PM
mount question
okay i have an eg...bout to do a b-series swap. i know which mounts you are suppose to use from an integra. but the 94-95 ex civic driver mount looks the same as the integra driver mount. Are they the same or not?
Malakai Jul 25, 2004 05:28 PM
i believe they are the same
hondaguyef Jul 25, 2004 05:35 PM
Re: (Malakai)
No, I don't think they are the same. I think the 92-95 civic mount is more offset than the teg mount.
gsrpwrdhb22 Jul 25, 2004 07:38 PM
Re: mount question (mphinesee)
i don't think they are the same either. A civic driverside mount usually only has 2 17mm bolts and the integra mount has 2 17mm bolts and 1 14mm. The civic mount may line up and all but that extra bolt is there for a reason. The b series motor does weigh a little bit more than the d series motor but it is a direct bolt up with the integra mounts. You can use the civic upper tranny mount
Turbogixxer Jul 25, 2004 07:43 PM
Re: mount question (gsrpwrdhb22)
http://www.we-todd-did-racing.com/we...MXk1NDE%3D.jpg
thanks Katman for the diagram
Turbogixxer Jul 25, 2004 07:45 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrpwrdhb22 &raquo;</TD></TR><TR><TD CLASS="quote">and the integra mount has 2 17mm bolts and 1 14mm. </TD></TR></TABLE>
All three are 14mm. The 17mm is the center bolt the holds the mount to the chassis.
hondaguyef Jul 25, 2004 07:46 PM
Re: mount question (turbogixxer)
That is a bad ass diagram https://honda-tech.com/forums/images/smilies/emthup.gif . I have always used the teg tranny mount as well though.
6shootahorsenamedtrigga Jul 25, 2004 09:33 PM
Re: mount question (hondaguyef)
The mount I am speaking of is the 94/95 d16z6 mount...looking at pictures they look the same; both silver with three bolt holes. But if that statement of "they are offset a little different" is true than that is the answer to my question. Can anyone else confirm that, thanks for all of yalls (country) input
6shootahorsenamedtrigga Jul 25, 2004 09:50 PM
Also I know for the 5g civic different mounts were used. For the vx motor (which i have https://honda-tech.com/forums/images/smilies/emsad.gif ) The mount is totally different from a d16z6 mount. It is black and has ( damn let me go look real quick) 2 offset holes (not parallel to the mount edge). But I am comparing the lookalike d16z6 mount to the teg mount.
6shootahorsenamedtrigga Jul 27, 2004 09:33 PM
anyone else know for sure that the mounts (95/95 d16z6 and integra mount) are different or the same?
