Mini Me parts list
I'm putting one together for my daily driver and I want to be sure I have all the correct parts.
Parts List: D15B7 bottom-end D16Z6 head Z6 headgasket VX timing belt(?) adj. cam gear I'm not too sure what timing belt to use, as I've read many different suggestions. I figure the VX belt is the one to use since this is essentially a 1.5L vtec. Let me know if this is correct or is there another option. Also any guessestimates on c/r? TIA. [Modified by cyber13, 1:32 AM 4/6/2002] |
Re: Mini Me parts list (cyber13)
i think you need the d16z6 timing belt. cant remember tho. my friend did this and read about 260 psi from a compression check across the board.
Re: Mini Me parts list (dlric)
whaever water pump you use is what timing belt you use.
Hey i am doing a y8 head swap onto my sohc zc and i am having the same problem, ive tried 4 different timing belts and they are either way too big or extremely tight. If anyone knows what belt i need please help. I used a 96+ belt, 92-95 belt (all too tight), d16a6 belt, and a 1990 civic base model 1.5l belt those 2 were too loose.
Re: Mini Me parts list (rainforest)
whaever water pump you use is what timing belt you use. |
