MASSIVE D16Y8 Head Onto D15B7/8 Block MiniMe Swap Writeup!!!
#126
Re: MASSIVE D16Y8 Head Onto D15B7/8 Block MiniMe Swap Writeup!!!
Today, thanks to this marvelous write up. I successfully installed a D16Y8 head complete with manual IM on my B7 block. I will chime in on a few things. You will need to block off the top vacuum nipple (driver side facing outwards) the D15B7 dizzy workes perfectly fine. I have an AEM tru timing gear advanced to 4.5*. Ran all the noted lines (both coolant and vacuum) to their partners. The one thing I didnt install was the IAC. Started right up, after a few timing trials and throttle cable adjustments it idles at a clean 1k. P28 ECU installed and running the setup (without a chip) Last thing left to do is run VTEC wiring and I'm mini me'd. I am living proof of this swap on a D15B7 block. I did have to t off into the coolant return line off the IM under the throttle body. No leaks, temp holds, better low end power. Happy, happy, happy.
#127
Thanks, seem like people are still following this thread, just got into the whole Honda scene due to how much power you can get out of those 4 bangers, this is my first build and wanted to try some tested and proven. Glad to read I can use the cam gear off the d15b7 for the y8 head. It is crazy how hard it was to find good info, glad I found it.
raider1qaz
02-01-2014 06:09 PM
