ls/vtec = horrible, horrible mistake... what's wrong?
My friend and i were getting onto the freeway and decided to test out his new car's power vs mine. He has a 94 integra with an ls/vtec and i have a 94 integra with LS motor. Now, before you start laughing about who's the better driver this was from a roll... he couldn't pull on me, in fact i pulled on him, just inch by inch... We shut down at 80 or so. We were wondering what the hell is wrong with his car... here's a little more info: b18b Block b18c1 head AEM CAI 2.25" exhaust DC 4-1 header Chipped with removed rev limiter CM stage 1 (kinda shitty) relativly light 17s My car: b18b AEM CAI DC 4-1 Header 2.5" exhaust 2.5" Cat MSD ignition (coil, SCI, wires) Fidanza flywheel (7.5 lbs) ACT XTSS clutch (rules) Falken Azenis on slipstreams What's the deal, -Ryan |
Re: ls/vtec = horrible, horrible mistake... what's wrong? (tegasaurus)
what transmission were each of you running? and well he may have to get the engine tuned..maybe his clutch is slipping so it doesn't fully engage when he shifts? also maybe your engine is a freak and is making power =P and tire/wheel size will make a difference in acceleration
Also, is he still running the stock LS Pistons, and he didnt upgrade to GSR or Type R. Just Curious because compression does play a factor as well.
um, is your friends VTEC working?
seems like it isnt... t.. |
Re: ls/vtec = horrible, horrible mistake... what's wrong? (tinkerbell)
what kind of ecu is he using and is vtec hooked up?
Re: ls/vtec = horrible, horrible mistake... what's wrong? (djhatch)
dont thinkt he vtec is hooked up. Once it is.. he should smoke you.
Re: ls/vtec = horrible, horrible mistake... what's wrong? (CRX_VTEC)
I hope if whoever took the time to do a ls/vtec would hook up the vtec.
Compression check? He may have a weak bottom end, bad rings? |
Re: ls/vtec = horrible, horrible mistake... what's wrong? (nsxmatt)
well when it hits about 5200 rpm it screams. I was thinking that maybe that was the secondary intake runners? We are gonna take it to a local ls/vtec specialist and ask him what the thinks.
He has the stock ls pistons, and a pretty nice clutch, no slipping at all. Thanks for you help guys. |
ls/vtec isnt fast unless you upgrade the internal and transmission. gsr or type-r the ls transmission has longer gears http://rely.net/~htimages/smile/emthdown.gif http://rely.net/~htimages/smile/emthdown.gif
Re: ls/vtec = horrible, horrible mistake... what's wrong? (SleeperEG6)
ls/vtec isnt fast unless you upgrade the internal and transmission. gsr or type-r the ls transmission has longer gears http://rely.net/~htimages/smile/emthdown.gif http://rely.net/~htimages/smile/emthdown.gif |
tell him to change the pistons too. some PR3, P30 would work wonders. http://rely.net/~htimages/smile/emsmile.gif
Re: ls/vtec = horrible, horrible mistake... what's wrong? (vbphreak)
Man, LSVTEC Is shitty unless it's done right...and your friend isnt even close to doing it right. Shoulda just bought a GSR Swap.
Suprdave |
Re: ls/vtec = horrible, horrible mistake... what's wrong? (Suprdave)
Man, LSVTEC Is shitty unless it's done right...and your friend isnt even close to doing it right. Shoulda just bought a GSR Swap. Suprdave |
Re: ls/vtec = horrible, horrible mistake... what's wrong? (integra707)
IS the vtec working correctly? when I had mine and vtec wasn't working I got killed by my friends ls by two cars. The motor was fully built also. In my experience a vtec head on a motor with the vtec not working is slower than a non-vtec.
Re: ls/vtec = horrible, horrible mistake... what's wrong? (ImportRacing)
What ECU is he running tho??? you said it opened up at 5200... If he's running a P72 you shouldn't be able to hear the secondaries like VTEC and the VTEC would kick much sooner.. My friend has a stock bottom end LSVTEC exactly the same as ur friends but it's in an EG.. It's not really fast but 13.4 isn't that bad... I still don't like stock bottom end LS/CRVTEC's they just won't make the power that one with pistons can.. I bet that tranny is killin him too... Fuck the LS shit... GSR will be fine but B16 or ITR will be even shorter.. Latez
[Modified by JDMspecEG6, 8:37 PM 11/25/2002] |
well when it hits about 5200 rpm it screams. I was thinking that maybe that was the secondary intake runners? We are gonna take it to a local ls/vtec specialist and ask him what the thinks. He has the stock ls pistons, and a pretty nice clutch, no slipping at all. Thanks for you help guys. Props to you my man http://rely.net/~htimages/smile/emthup.gif |
Re: ls/vtec = horrible, horrible mistake... what's wrong? (hot_EG)
haha, rpm's ='s revolutions per minutes... neato.. http://rely.net/~htimages/smile/emsmile.gif
Re: ls/vtec = horrible, horrible mistake... what's wrong? (JDMspecEG6)
What ECU is he running tho??? you said it opened up at 5200... If he's running a P72 you shouldn't be able to hear the secondaries like VTEC and the VTEC would kick much sooner.. My friend has a stock bottom end LSVTEC exactly the same as ur friends but it's in an EG.. It's not really fast but 13.4 isn't that bad... I still don't like stock bottom end LS/CRVTEC's they just won't make the power that one with pistons can.. I bet that tranny is killin him too... Fuck the LS shit... GSR will be fine but B16 or ITR will be even shorter.. Latez [Modified by JDMspecEG6, 8:37 PM 11/25/2002] I've run another LS with my low CR LSVT setup (with my VTEC disengauged) and I was RIGHT there, but they kept inching on me every gear. X2 |
Re: ls/vtec = horrible, horrible mistake... what's wrong? (X2BOARD)
You may hear them open up a little but it still isn't like a VTEC x-over.... http://rely.net/~htimages/smile/emsmile.gif
Re: ls/vtec = horrible, horrible mistake... what's wrong? (efzero.com)
Is there a way to test the vtec solenoid to see if it's working? I'm thinking the ECU might be incorrectly tuned etc. When he gets some money, i'll try and interest him in a mugen ecu or a jun ecu or a gsr tranny...
gsr trannys are currently going from 700 to 1000. I can't find anything cheaper than that. Also, since he pays for his gas he doesn't like the idea of cruisin at 80mph at 4000 rpm. Is it possibly to use a gsr 2nd and 3rd gear in an ls tranny? Thanks, Ryan P.S. keep the thoughts and ideas comin, more ideas, the faster we can fix this! thanks guys. |
ry tec! Suggest that RC sell his ls tranny when he buys a gsr tranny, thatll save him some money. Also tell him that i'll put gsr pistons in his block if he wants to. I told you to tell him NOT to buy that car... oh well, i wanna work on that car.
number one....you have lightweight flywheel and smaller rims and tires!!!
that will be the difference... you said lightweight 17's.....ROFLMSAO |
Re: ls/vtec = horrible, horrible mistake... what's wrong? (Chad)
i guess 18lbs is heavy.... http://rely.net/~htimages/smile/emhammer.gif
