K20 into 88-91 crx?????
I recently talked to hybrid racing and they said they were coming out with a mount kit very soon but i dont know how soon that will be so if anybody knows any other companys producing these kits hit me up
Re: K20 into 88-91 crx????? (jonny50979)
Everything is custom at this point, there are quite a few K series EF's running around. A few company's are in the process or r+d for the mounts, most of which should be out soon.
Re: K20 into 88-91 crx????? (VTECVillain)
I wouldn't hold my breath for that 88-91 kit to come out... https://honda-tech.com/forums/images...s/emsmilep.gif
You will have two choices with that swap; bad ground clearance or custom hood. One of them will have to be chosen.
It seems that this swap will have to be about compromises. |
Re: K20 into 88-91 crx????? (rochesterricer)
The swap is perfect for my drag car though.Hood clearance isnt a problem,ive got a sinsei 1 piece front end,and ground clearnace isnt a problem,because since the engine sits at the axles center line,the engine can sit as low as i need it to without tripping the staging beams.For a street car youre gonna have to either cut a hole in your hood or run an aftermarket hood.Everything is custom until companies come out with mount kits.From what ive heard its going to be a few months.
