K series shifter box with H22 swap?
#51
Re: K series shifter box with H22 swap?
H2B is a thing of the past! Why anyone would choose a sh!tty H2B adapter plate over the options that are available now is beyond me... Most JDM H transmissions have better gearing than most B trannies anyways. You can buy the shifter that pops right into the EG shifter footprint now. Wish they had that when I did my swap! It's cool though because the k shifter plate gets it done!
#53
#56
Question, if I where to do use the RSX shifter box could you run both cables through the firewall where the heater core would be, like in a K Swapped car? Or would they not align correctly and would the longer cable have too much slack? Not very familiar with H Series trans
#58
RSX style shifter, RSX shift cables, K-Tuned H22 billet cable bracket. I am not sure if the mounting holes match those in the 4G Lude, so you may have to modify the tunnel slightly. A K-Tuned mounting plate could be modified and eliminate permanent modifications to the chassis, but it may make the shifter assembly too tall to fit under the stock console plastics. Then again, they may not fit anyway. Good luck.
#59
Already have this setup completed in a 4th gen lude.
Hybrid Racing Shifter Box
KTuned OEM Spec cables
KTuned H/F Tranny Bracket
It is sooooo nice. lol.
pullin crx hf
21
03-09-2012 04:21 PM
Maddox
04-17-2005 08:32 AM
