JDM B18c 98+ Spec Emissions in AZ
Hello all, I am currently near completion with my project EK but will be running into emissions in Arizona soon. I swapped a JDM B18c 98+ spec engine with all stock internals and am currently running a Hondata S300 which is an OBD1 in an OBD2 car (00' Civic CX). To my knowledge, I know that plugging the supplied JDM ECU will not get it to pass through emission and have been trying to research to get a concrete answer as to what steps to take for it to be passed. So far I've been seeing that I would either have to get a USDM oil pump since the Crank Knock Sensor are on the USDM B18c or bypass that through a different method but unsure of what the specifics are exactly. There is possibly more I would need to do in order to but does anyone have any insight or experience as to what it is I need to do exactly to get it to pass emission. Any info and help is much appreciated.
Re: JDM B18c 98+ Spec Emissions in AZ
Not sure about your question but maybe you can answer one I have. I've been contemplating the idea of swapping a JDM 98 spec R motor in to my 01 USDM ITR. What steps are necessary to do the swap as far as keeping the car OBDII and passing emissions? I really don't want to step down to OBDI.. Any help would be appreciated. Thanks
Originally Posted by jdmmugenbb6types
(Post 51587562)
Pretty sure the 98-01 specs are OBD2a as well. |
