Identifying a JDM B20B block.
Whats up everyone. Anyone have any pointers or things to look for to be certain a B20 block is in fact a JDM B20b block. Any help would be appreciated. Thanks
Remy |
Re: Identifying a JDM B20B block. (Zynentech)
From what I have heard is on the block where it says B20B on the US spec engines there is a number that follows it like B18C5 and from what I have heard is that the Japanese spec engines do not have that last number following the block so it would be the B18C engine instead. I am not 100% sure if it is true but I think it is. Hopefully this might help.
Re: Identifying a JDM B20B block. (MugenCivicHX)
From what I have heard is on the block where it says B20B on the US spec engines there is a number that follows it like B18C5 and from what I have heard is that the Japanese spec engines do not have that last number following the block so it would be the B18C engine instead. I am not 100% sure if it is true but I think it is. Hopefully this might help. |
Re: Identifying a JDM B20B block. (Jared)
the harness will be going the other way of the motor(right hand drive)...
Ok well I have a question for you Jared how would you tell the difference between a JDM GSR motor and a JDM type r motor wouldnt the both be B18C's I know the type r has the red cover but someone could do that to a gsr too right
