i have 2003 honda accord ex coupe with lsd 6 speed
im consider placing j32 heads and manifold after i have high performance valves and spring and springs installed ...and placing 72 mm throttle body -----that coming off 3.2 acura tl -----or im consider doing a swap with j35 acura engine after rebuild it ----im trying gain more horse power....or any suggestion .....i had the suggestion of adding turbo to my j30 ...the cost to have turbo place is alot more money to have don correctly....this great car that have built h22 r type engine with lsd tranny in another car i owned and sold it and made great return .....My goal is get as much horse power out this car as possible without spending to much as i can buy both engines for 300 ---i have access to high perfomance parts at whole sale cost ....
Re: i have 2003 honda accord ex coupe with lsd 6 speed
I would just drop in a J35 and call it a day; best bang for the buck.
Agree with dropping in the J35. |
j35 is the fastest way. boltons respond will to this motor as well. get the intake manifold ported also. be sure to find someone who can tune the motor first along with a good engine management
thank you for the response will i need to change the bellhousing
Originally Posted by luther69
(Post 52023492)
Originally Posted by shipo
(Post 52023504)
It depends upon which J35 you drop in. If you go with a J35A3 the engine should literally bolt in. By the way, where did you get the LSD for your 6-Speed; my understanding is the Accord didn't come with the LSD version of the 6MT.
Originally Posted by Freedo_Civegra
(Post 52026506)
I think the K-series LSD can be modified slightly to fit these.
(Post 52026559)
Hmmm, first time I've heard that. Do you have any references I can look up?
