help. how to remove old intake gasket? thanks
just got my b20 and i want to install my new intake gasket. im using a b18b manifold and it has old gasket stuck to it.. what is the safest or way to remove it without messing something up? thanks... https://honda-tech.com/forums/images...es/emdgust.gif
Re: help. how to remove old intake gasket? thanks (jdmekcivic)
buy a can of gasket remover
mmm gasket remover. shit works too
Re: (b20_EK)
propane torch, razor blade, fingernail..(if you haven't cut them in a while). It only took me about 2 minutes with the torch(it's actually mapp gas, but it's only a little hotter) and a razor blade, to get all the gasket off a turbo mani from an MR2 turbo, and that shit was on there, that turbo glows bright red...
What gasket are you putting on your b20?
I'd use a putty knife always work for me. just my .02
Re: help. how to remove old intake gasket? thanks (egCivicDon)
stock gasket.....
hondata gasket makes it much easier
