Help: H22 swap in EK vibration at acceleration
I have had this swap for a year now and i finally got an LSD tranny for it (M2B4) but since i took off the tranny i decided to go get the clutch resurfaced etc... So when i was putting the driver side axle and one of the bearings fell so i bought new axles off kragen 89 integra for pass. side and a 90 integra for driver side. Car doesnt vibrate much when its idling its when i start driving it pass 15mph...........i've put it on the lifters and put it on gear and doesnt make any noise...... Thanks for help in advance
Re: Help: H22 swap in EK vibration at acceleration
Is there very little vibration? How does the steering wheel feel?
everything is tightened up? lug nuts, bolts, axle etc..
Originally Posted by rellikgtx
(Post 42438736)
and yes i made sure everything was tight cus i have at least taken off the axles like 5 times to check that the axles are still fine and then bolt everything back up |
Halfshaft?
i checked tha halfshaft and it has no play, cus i put the car up in the air and it doesnt vibrate at all
i lifted the suspension all the way and the car is running fine now so figure its my ride height lol........ since i was rokin 195/55-15 and bought some other rims that had 195/50-15, my best bet is that ihave to rock 16's
Originally Posted by bluEK
(Post 42467900)
I Have the same problem hopefully i can solve this the same way due to ride height.👍 |
It's bad axle alignment. It comes from bad CV joint or if you are lowered, obviously this will cause axle alignment to be off.
