Hasport EFB2, DC2 mount brackets work?
I'm swapping a B18C with hydro tranny into my '88 CRX using the Hasport mounts. Everything I read says you need the 90-93 (DA integra) timing belt side, and tranny mount brackets. I have both brackets from a DC2, and I'm just wondering if these will suffice, as they look very similar from the pics I've seen. Also, I don't know if it will make a difference, but the DC2 frontcut came with an auto tranny.
Thanks. |
Re: Hasport EFB2, DC2 mount brackets work? (dave_ed9)
You definitly need the 90-93 Integra mount brackets, the 94-01 Integra parts look similar but they are not the same.
Re: Hasport EFB2, DC2 mount brackets work? (keithg)
just bought a simular kit efb2 hydro. put it in today. works like a charm. but the drivers side mounting bracket I had to get of my 1st gen b16a. the motor I put in was a b16a2 sir.
Re: Hasport EFB2, DC2 mount brackets work? (22psicrx)
you need a rear bracket from hasport. the other one does not clear the cross member.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 22psicrx »</TD></TR><TR><TD CLASS="quote">you need a rear bracket from hasport. the other one does not clear the cross member.</TD></TR></TABLE>
are you saying the 90-93 bracket will not clear it? or the 94-00 one? |
You definitly need the 90-93 Integra rear mount bracket. Please refer to the installation instructions. http://www.hasport.com/Tech/Installs/EFB2.htm
Please note that the bracket needs to be modified to work with a hydro trans as per the instructions. Hasport can sell you a modified OEM Honda rear mount bracket if you don't have one. |
