which harness to use
im putting a b18c1 into a civic(d16y8). im getting a half cut. most guys are telling me to use the civic wiring harness. would it be better to use the integra harness cos itll still be plug in?? all i have to do is plug it up the the shock towers?? and do i have to change the crossmember?? or is it only recommeded
Re: which harness to use (ah789454)
if the car is a 96-civic I like to use the stock harness and add the necessary wires and such. lots easier as you can't use the gsr harness on those model cars. as for crossmember no need to mod if this is a 96-civic you are doing the swap into
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ah789454 »</TD></TR><TR><TD CLASS="quote">im putting a b18c1 into a civic(d16y8). im getting a half cut. most guys are telling me to use the civic wiring harness. would it be better to use the integra harness cos itll still be plug in?? all i have to do is plug it up the the shock towers?? and do i have to change the crossmember?? or is it only recommeded</TD></TR></TABLE>
you need to use the civic wiring, and hondas dont really have crossmembers to change. why are you getting a clip? you dont need one. |
Re: which harness to use (Kamin)
im getting a front clip cos only 1.8k (about 1.3kUS) im in australia, japan i just up the road thats why so cheap...lol
can you guys help me out here...
i am going to drop a 94 gsr into my 99 civic. what wiring (engine)harness do i need to use? can i use my stock d series (non vtec) harness and just get the vtec rewired? Thanx |
Re: which harness to use (jaydm ferio)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaydm ferio »</TD></TR><TR><TD CLASS="quote"> can i use my stock d series (non vtec) harness and just get the vtec rewired? Thanx</TD></TR></TABLE>
Yes, you have too |
| All times are GMT -8. The time now is 07:30 AM. |
