H2b / f2b hybrid stroker motor dyno results
#27
Re: H2b / f2b hybrid stroker motor dyno results
it is under construction and will be turbo, important to me your experience! experience of other builders h-series long-block!!! many graphics fall at earlier revolutions, I am sure that this is due to the high velocity of the piston !
#30
#31
Skunk2 said the pro series are not good for boost, they recommended the tuner series I believe.
#32
Its all in the tuning man. I personally built a B series car with pro 1's on a gt35r that made a tad over 700. The tuner is the key to making power. And the tuner cams are garbage in my opinion
#33
That could be true. I was just repeating what I heard from skunk2; and they obviously recommended me to another skunk2 product so it can be discredited and viewed upon as a biased opinion to an extent; but then again everyone swears by the pro2 cams which is why I got them. It would be nice to see a dyno sheet comparison for different H cams so you could really tell which is the best for boost. I am thinking about boosting this one by next summer but not really sure yet.
#34
I know its a late response on this one, but can you run oversized valves using skunk2 pro 2 cams?
#35
Proven for couple years pro 1s NA work on turbo well.... Not too big of a cam but has what the turbo likes...
V-SPEC 1
25
07-19-2016 10:05 AM
VtecKiDD
76
11-11-2005 10:22 PM
