h23 ->h22 thermo...
Has anyone tried swapping the h23 therostat whith th h22s?
Re: h23 ->h22 thermo... (racerx)
i haven't personally, but they will work with eachother being the same temp.
the h23 is too small for the h22.
Re: h23 ->h22 thermo... (Qfactor)
I know the thermo itself is too small. I looked up part numbers to see if it was possible at all so that I can get a lower temp one that everybody makes for the vtec. I figured it would take about $80-$100 in parts. The housing down the the pipe going into the block need to be replaced with h22 counterparts. From my view point, it'll work. I just wanted to know if anyones done it so I don't buy a bunch of parts I can't use.
| All times are GMT -8. The time now is 08:51 PM. |
