H22a swap idles at 2000rpms. Please help.
Car is 94 Civic with JDM H22a. FITV has been blocked off for a long time. Was running great the last two weeks, all the sudden is idling at 2000rpms. No CEL, I've replaced the TPS, cleaned the throttle body and IACV with carb cleaner, checked throttle cable tension/position and checked for vacuum leaks. Still is idling at 2000rpms. Bleeding the coolant is my next step, but damn... I don't know what else it could be, kinda stumped, could really use some help or suggestions from here. No idle bounce, car seems to run fine, idle is just stuck at between 2000rpms.
Thank you in advance for any help. |
Re: H22a swap idles at 2000rpms. Please help.
Bump. I still really need any help.
what ECU are you using? Any CELs??
Recheck the throttle body gasket for any cracks or broken pieces. Double check all vacuum lines and block off anything not being used with a cap.
Sounds like a possible vacuum leak. Spray starting fluid around intake mani and tb while runing. If revs change there is a vacuum leak somewere.
I believe the ECU is a chipped p28. No check engine light illuminates but when I jump the plug to get a code, it gives me 14 and 7. But nothing when I don't jump the plug. Car seems to drive fine, just idles at 2000rpm.
I did spray carb cleaner all around the throttle body and IACV. When I spray the carb cleaner around those two areas the idle does drop down from 2000 for a few seconds then jumps right back up. |
Code 14 --- IAC Valve (Idle Air Control) defective circuit or unplugged / defective sensor
Code 7 --- TPS (Throttle Position Sensor) defective circuit or unplugged / defective sensor I'm betting you got these two swapped around. |
Well out of nowhere, now it's running terrible. The idle has dropped back down to around normal but now it fluctuates up and down and more or less feels/sounds like it's running on 3 cylinders. It seems like it's running real rich too. I'm about at a end with this car.
I made a video of what the car is doing now;
Here's a complete run down of everything done to the car; Motor JDM H22 w/ LSD Transmission Clutch Master Stage 3 Clutch and Flywheel Innovative Motor Mounts Innovative Alternator Relocator Bracket OEM JDM H22 Type S Red Valve Cover Billet Aluminum Spark Plug Cover Chipped P28 ECU B&M Fuel Pressure Regulator B&M Fuel Pressure Gauge Removed Power Steering Unorthodox Racing Alternator and Crank Pulley Optima Yellow Top Battery OPD51R Battery relocated in trunk Password JDM Reservoir Covers OEM JDM ITR Oil Cap Hondata Heat Shield Gasket Spoon Magnetic Drain Plug Yonaka Radiator Mugen Thermostat Mugen Fan Switch MSD SCI Ignition Control, Blaster SS Coil, Black Super Conductive Wires, Modified Extreme Honda Cap, Rotor Apexi World Sport Exhaust AEM Cold Air Intake AEM Dry Filter AEM Fuel Rail Forbidden Motorsports True Short Throw Shifter Exterior Nissan G35 Silverstone Paint JDM Thin Mouldings Shaved Antenna (replaced with interior antenna) Shaved Trunk Key JDM Style Fenders with Side Markers Mugen WWRS Style Front Lip Black Spoon Style Mirrors DOHC VTEC stickers JDM OEM Fog Lights JDM Amber Corners Seibon Carbon Fibre Hood Window Tint Black Muteki Open Ended Lug Nuts Benen Tow Hooks Interior JDM Center Console JDM ITR Shift Boot JDM ITR Shift Knob Alarm System with Power Windows, Power Locks and Power Trunk Alpine DVA-9861 Deck Suspension Tein Super Street Dampers with Pillowball Upper Mounts 205/45R-16 Bridgestone Potenza RE-01R Motegi Traklite 1.0 Wheels Eibach Anti-Roll Kit Energy Suspension Black Bushing Kit Skunk2 Lower Control Arms Skunk2 Front Camber Kit Aspec Subframe Reinforcement Brace ITR 5 Bolt Brake Conversion AEM High Performance Brake Pads Mugen High Performance Front and Rear Brake Rotors Mugen Micro-Mesh Brake Line Set Brake Calipers Powder Coated Black |
OP, go to your other duplicate thread. My suggestion reply is on there
