H22 Swap for my EK
I Wnated to know what intake do i use and if the civic fluindye radiator whas good enough or should i get the integra one? also what headers are good ? And whats the recommened NOS shot (WET)? https://honda-tech.com/forums/images...s/emhammer.gif https://honda-tech.com/forums/images.../h-emblem4.gif
Re: H22 Swap for my EK (type-ryellowEk9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by type-ryellowEk9 »</TD></TR><TR><TD CLASS="quote">I Wnated to know what intake do i use and if the civic fluindye radiator whas good enough or should i get the integra one? </TD></TR></TABLE>
People on this board are running the stock civic radiator with no problems. <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by type-ryellowEk9 »</TD></TR><TR><TD CLASS="quote"> And whats the recommend NOS shot (WET)? </TD></TR></TABLE> I recommend a Dry shot with a stock manifold. Dry shot has no fuel going though a intake manifold that is not designed to have fuel running though it(aka fuel puddling). I think that 75 shot would be no problem for a stock set-up. You can go higher, but make sure that you are running the right a/f ratio. |
For the radiator if you're running the hcp mount with the front bar, then you would need to run a pusher fan for the radiator and mount it in the front of the radiator.
Re: H22 Swap for my EK (H22ek4)
Aye, you might want to look into a del sol vtec radiator if you're worried about heat...and a bunch of people are using the AEM Intgera Type R intake.
