H22 Newb Question
Newb Here. Im really considering getting the H22 over the B18c but a friend of mine told me (hes got a H22 in an EG) that.... say your at the track and you give it a good 5 hard runs its starts to feel slugish after the 5th or 6th run and you need to kind of take a time out till you can go hard again. But if you got a B series you can give it hell all day with out problems. Is this tru or is his motor on its way out.
Thanks |
Re: H22 Newb Question (oacrep1)
what your freind is talking about isnt the motor its self. after you do so many runs you clutch and flywheel starts to heat up. after it gets to hot the clutch will start to slip hince the sluggish feel. get a good clutch and dont give it hell back to back with out some kind of break then you will be just fine.
