H22 manual tensioner conversion
I am trying to convert my h22 to manual tensioner, and i know that 2point6 did an awesome right up on it but i can't find it anywhere. is there anyway that someone could hook me up with that post. or if someone else would care to explain it to me thatd be cool too thanks.
Re: H22 manual tensioner conversion (CivicSH)
This seems to be a hot topic for the H22 owners out there. Here is a step by step "how to" conversion to the more reliable H23 (manual) style of tensioner. The H22a block used, is obviously a "mock-up", so don't be critical of the missing pieces. This conversion can be done in the car, but in this case it was done out of the car for illustration purposes only.
Parts list: 13404-PT0-004 - ADJUSTER COMP., BALANCER BELT 13415-PT0-000 - BRACKET, BALANCER BELT ADJUSTER 14510-PT0-004 - ADJUSTER COMP., TIMING BELT 14516-PT2-000 - SPRING COMP., TIMING BELT ADJUSTER 14521-P14-A00 - PLATE, ADJUSTER 90014-P14-A00 - BOLT, TIMING BELT ADJUSTER BASE 90015-PT0-000 - BOLT, TIMING BELT ADJUSTER SPRING 90016-PT0-000 - BOLT, TIMING BELT ADJUSTER 90140-P14-A00 - WASHER, PLAIN (11MM) Here is a link for the parts list: http://www.hondaautomotivepart...82%29 This is a frontal and side shot of what the auto tensioner set up looks like with the timing belt cover, balance shaft crank pulley, balance shaft belt, and timing belt out of the way. All of these thing will need to be removed to do this conversion. http://www.collectiveracing.net/images/howto/e/e030.jpg http://www.collectiveracing.net/imag...to/e/e0007.jpg Start by removing the auto tensioner pieces. These following pictures should be fairly self explanitory. http://www.collectiveracing.net/imag...to/e/e0008.jpg http://www.collectiveracing.net/images/howto/e/e021.jpg http://www.collectiveracing.net/images/howto/e/e026.jpg These following pieces will be removed from the h22 in this step and set aside for later use. http://www.collectiveracing.net/images/howto/e/e031.jpg With the parts removed this is what it looks like. http://www.collectiveracing.net/images/howto/e/e013.jpg This step, we will remove the troubsome auto tensioner. http://www.collectiveracing.net/imag...to/e/e0006.jpg With the auto tesioner gone, we will remove the rest of the tensioner mechanism. The following pictures should be self explanatory. http://www.collectiveracing.net/images/howto/e/e025.jpg http://www.collectiveracing.net/images/howto/e/e014.jpg http://www.collectiveracing.net/images/howto/e/e032.jpg http://www.collectiveracing.net/imag...to/e/e0004.jpg http://www.collectiveracing.net/imag...to/e/e0009.jpg Now, with the complete auto tesioner mechanism removed, we are ready to add the manual tensioner parts. http://www.collectiveracing.net/images/howto/e/e022.jpg This bolt and washer are what we start with. The factory washer is critical! It has a larger diameter than the block casting. This is a factory Honda part #90140-P14-A00 - WASHER, PLAIN (11MM), but for those of you who are lazy or pinching pennies, the diameter is 40mm and the thickness is 3mm If the wrong washer is used, improper alignment can occure as well as limited movement of the timing belt tensioner pulley. http://www.collectiveracing.net/images/howto/e/e016.jpg http://www.collectiveracing.net/imag...to/e/e0003.jpg http://www.collectiveracing.net/images/howto/e/e017.jpg These 2 pieces will be added next. http://www.collectiveracing.net/images/howto/e/e012.jpg http://www.collectiveracing.net/images/howto/e/e019.jpg http://www.collectiveracing.net/images/howto/e/e029.jpg http://www.collectiveracing.net/images/howto/e/e044.jpg Add the timing belt tensioner pulley and check to see if it has full movement on its pivot. http://www.collectiveracing.net/images/howto/e/e036.jpg http://www.collectiveracing.net/images/howto/e/e037.jpg http://www.collectiveracing.net/images/howto/e/e038.jpg http://www.collectiveracing.net/images/howto/e/e045.jpg Next we will install the balance shaft tensioner pulley. For this install, we will re-use the H22 part. The H23 part has a larger spacer that places it further out away from the timing belt pulley. I recomend using the H23 part (not shown), but with a few washers (used as spacers) the H22 pulley (pictured) can be used correctly. http://www.collectiveracing.net/images/howto/e/e047.jpg http://www.collectiveracing.net/images/howto/e/e048.jpg http://www.collectiveracing.net/images/howto/e/e050.jpg If you are reusing the H22 part, MAKE SURE THE PULLEYS CLEAR EACH OTHER! This is a common mistake and can be catastrophic. When reusing the h22 balance shaft tensioner pulley, the pulleys must not touch! if you are using a h23 balance shaft tensioner pulley, there is no need to worry. it is already spaced properly. http://www.collectiveracing.net/images/howto/e/e039.jpg Reinstall the balance shaft tensioner retainer. http://www.collectiveracing.net/images/howto/e/e041.jpg Manual style tensioner in place completely. front and side views. http://www.collectiveracing.net/images/howto/e/e043.jpg http://www.collectiveracing.net/images/howto/e/e042.jpg catch it now, I will take the pics down in a few days |
Re: H22 manual tensioner conversion (Turbogixxer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbogixxer »</TD></TR><TR><TD CLASS="quote">
catch it now, I will take the pics down in a few days</TD></TR></TABLE> Save it while it's hot... |
