h22 h22a Civic 1/4 Quarter 1320 mile times (Search Friendly)
#201
13.7 @ 102 first run with new setup 2.39 60ft. I/H/E stock clutch and a FUCKED alignment. (camber kit slipped) the car felt really funny going down the track
Was poor as hell those days so couldn't afford to get a clutch and slicks to really see what it was capable of.. however, I find the mid 12 second runs with basic bolt ons and stripped very believable.
CANT WAIT TO GET THE TO THE TRACK WITH THE TURBO, SLICKS AND CLUTCH AND 100+LBS LIGHTER.
#202
Re: (2point2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2point2 »</TD></TR><TR><TD CLASS="quote">13.7 @ 102 first run with new setup 2.39 60ft. I/H/E stock clutch and a FUCKED alignment. (camber kit slipped) the car felt really funny going down the track
CANT WAIT TO GET THE TO THE TRACK WITH THE TURBO, SLICKS AND CLUTCH AND 100+LBS LIGHTER.</TD></TR></TABLE>
is that in a crx?
is that in a crx?
#203
Re: (The Source)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Source »</TD></TR><TR><TD CLASS="quote">is that in a crx?</TD></TR></TABLE>
yep.. I wouldn't take the 13.7 too seriously. an h22 can easily take a CRX to 12 second territory.
Modified by 2point2 at 11:07 PM 8/24/2006
#204
Re: (2point2)
Modified by 2point2 at 11:07 PM 8/24/2006</TD></TR></TABLE>
thats what i was thinking haha.
#205
Banned.
Re: (2point2)
very true! I ran consistant 106 mph times on street tires i/h/e 90 crx hf JDM H22A for me bogging off the line and no back pressure with no muffler straight 2.5" kinda killed me... definetly 12s with slicks is reasonable...
#206
12.5 in the quartermile
h22a4
jdm camshaft
tranny LSD
integra axle with accord boot and gsr half shaft with integra axle
full race traction bar
skunk2 drag lock
dc 4-2-1 header
straight pipe
MUGEN CHIP ECU GSR
field VTEC controller at 5800
motor is stock but was drop in a CX SHELL
h22a4
jdm camshaft
tranny LSD
skunk2 drag lock
dc 4-2-1 header
straight pipe
MUGEN CHIP ECU GSR
#207
Re: (dapump2003)
I thought I'd update this "Search Friendly" thread
93 CX Hatch
I/open header
stock motor/trans open diff
street tuned on crome
2.1 60ft
13.7@101
BFG's
1.9 60ft
13.1@103
on 22's M&Hs
both sets of tire/slicks were brand new, maybe tires will get stickier, or driver get better
93 CX Hatch
I/open header
2.1 60ft
13.7@101
BFG's
1.9 60ft
13.1@103
on 22's M&Hs
#208
Re: h22 h22a Civic 1/4 Quarter 1320 mile times (Search Friendly)
93 EG EX-Coupe
JDMH22a
Skunk2 Pro 2 Camshafts and Total Drivetrain
Skunk 2 Cam Gears
9.5lb Flwheel
Stage 3 Clutch
Bottom End Stock
MSD Ignition Box
MSD Coil Pack
MSD Ignition Wires
Bosch Quad-fire Platinum Spark Plugs
EURO R Intake Manifold and Throttle Body
Walbro 225 Fuel Pump
Larger Diameter Steel braided Fuel Lines from Pump to Motor
Fuel Regulator
RDX Fuel Rail/Injectors (Soon to be put on)
Hondata S300 ECU
I'm hoping I can run a 13 flat...might be optimistic. I'm actually shocked that all you pulled on a Stock h22a was high 14's, that's kind of slow considering me seeing B16's even D series motors in the same chasis Pull faster past times.
JDMH22a
Skunk 2 Cam Gears
9.5lb Flwheel
Stage 3 Clutch
Bottom End Stock
MSD Ignition Box
MSD Coil Pack
MSD Ignition Wires
Fuel Regulator
Hondata S300 ECU
#210
have any of you seen the vids on you tube of the stock h22egs running slick and getting 13.5s and such in the 1/4.what do you guys think of that.i just did the h22 swap in mine and havent had time to race but 13.5 sounds crazy fast to me
#211
I am going to the track tonight. Will post times when i get home
Here is my setup
94 hatch dx full interior
h22a jdm swap m2a4 open diff.
p13 stock ecu
8lb fidanza with exedy clutch
cheap tires that are 205/50/15 (sidewall says only mount on 16" wheels, yes thats how bad of a company they are, i can take pics to show if anyone cares, i LOL'ed at it when i read it)
2.25 exhaust
stock header
twin loop muffler
rota hm'3s (15x7 35mm)
hasport mounts n axles.
WIll be racing at 6 30 til 10 tonight so as soon as i get home i'll post up how i did.
Here is my setup
p13 stock ecu
2.25 exhaust
stock header
twin loop muffler
#212
very unhappy, no traction... all i did was spin 14.05 @ 101 was my best
i need to replace my tires and go back.. also my 2.25 exhaust has got to go too.
btw, car weighed 2155 with me NOT in it on the scales...so i have to say the h22 swap sure didn't change my overall weight much if any...
#213
Wow, just got on H-T for the first time in probably 8 years easily. Can't believe someone posted to this thread 6 years after I created it.
To answer this, although it is a year old, when I put my h22 into my eg vx trim, I did 13.7 no problem on falken azenis I believe. I did this with tons of, hmm, I forgot what you even call it anymore, but basically the entire car "hops" off the line. Anyhow, that 13.5 w/ slick would be a no brainer. I would guess, even with my terrible driving, a 13.3 w/ full race slick.
