h22 eg pass. axle popping out problem.
hello, i just switch my h22 from one shell to another bout a month back. before hand the motor was sitting crooked and was breaking axles. when i switched the motor i moved the pass side mount towards the fire wall 3/4 of an inch. now the pass. side axle keeps popping out a 1/2 inch. im using DA integra axles. is there a 1/2 inch longer axle out there? or could i washers on inside of the hub to extend it a bit?
Re: h22 eg pass. axle popping out problem.
i was having the same problem in my ek. i just bought some hasport swap axles for it and sofar so good but i havent moved the mount back at all.
Your axle keeps popping out because you don't have what you need for it to work...
You must put on a Accord or Prelude Inner Joint on the passenger side axle, so the clip can clip in. With the Integra it wont, there for when you turn or any movement pops out, eventually can cause destroying a trans... Integra Passenger Side Axle with Accord/Prelude Inner Joint |
i got a backyard full of accord parts. so can anyone link me to a how to switch that stuff out?
Pretty simple and messy...
1) put axle straight up in vise 2) use a special tool that will undo the clip of the boot without destroying it, or cut it, go to Honda and you can get a new clip for cheap that should adjust to whatever you need. 3) slide inner joint off, slide new joint on, make sure tons of grease and bearings are aligned. 4) tighten down boot clip and do a dance... |
