Gsr iab help!
I have a 96 integra with a jdm b20 block and a jdm gsr head. It has a skunk2 intake mani and throttle body. Im running a chipped p28 ecu...what the hell do i do with the iab stuff? How do i wire it into the ecu or bypass it or whatever i need to do for it to work? Any help is appreciated!
Re: Gsr iab help!
iab?
Re: Gsr iab help!
Re: Gsr iab help!
Why you ask about iab if you have a skunk2 intake manifold and a p28
Re: Gsr iab help!
If you leave it as is they will stay open all the time of you had a GSR manifold. Otherwise just leave all the wiring and vacuum line items to the side or remove it (vacuum items)from the bay.
| All times are GMT -8. The time now is 10:52 PM. |
