Good or Bad???
Well I took the new hybrid to the track last night. It is a 95 Honda Civic Ex Coupe w/ a stock B18C1 motor. I ran on full interior, 17's, body kit, yada, yada, yada... Here is a couple of the timeslips:
http://www.teamneusion.com/timeslips/runGSR_1.jpg Here's another run... http://www.teamneusion.com/timeslips/runGSR_2.jpg And another run... http://www.teamneusion.com/timeslips/runGSR_3.jpg Is this good? Based on our altitude of 2600 ft. and the fact that it was 104 degrees outside the corrected et would be 15.07. What should the car be running the 1/4 in? [Modified by dragonsmp, 11:52 PM 6/7/2001] |
Re: Good or Bad??? (dragonsmp)
Doesn't sound too bad for a stock motor. I think your car is pretty light ... did you ever run it with the turbo SOHC you had in there before?
Re: Good or Bad??? (mplex2000)
Sure did... ran a best et of 13.7 @ 106mph on 15psi w/ street tires. Hopefully when I put the DRAG Gen3 kit on next week I will be in the mid-high 12's.
Sweeeet .. at least your clutch should get to me today, but the damn flywheel won't be here until next Tuesday http://images.zeroforum.com/smile/emsad.gif Ah well...
I still have to send you the throwout bearing. The engine and tranny is at my mechanic's house and he is out of town till next week so I can't get it till then. I will send when he gets home though. I finally got some pics of my car scanned and the new motor. Check it out, here is the link.
www.TeamNeusion.com/gallery.asp |
