Finally Got it started, but ............ I get a code 22
I have a b16a into my 91 hf. Me and da-max were able to get it started last night https://honda-tech.com/forums/images/smilies/emthup.gif but i get a check engine light, https://honda-tech.com/forums/images...s/emthdown.gif So he checked the ECU and got a 22. Online it says something about oil pressure. Anyone have any ideas? this is what the site says.....
VTEC Oil Pressure Switch defective circuit or unplugged / defective oil pressure switch Thanks |
Re: Finally Got it started, but ............ I get a code 22 (Slvr_CRX)
Yeah. Go out UNDER the hood. There is a 'sensor' to the passenger side off the back on the right hand side of the car. Make sure that something is plugged into it.
If not, find out why. It should go to the ECU so that your vtec can engage. Scott |
Re: Finally Got it started, but ............ I get a code 22 (CRneXt)
Hmmmm My vtec oil pressure test port screw was lose and i had some oil leaking out. Do you think that it could of caused my ECU code 22? I cant test it out because I have to use Da-max's fuel screws because mine has not arrived yet from Honda.
Thanks Modified by Slvr_CRX at 7:06 PM 4/6/2004 |
bump
yes that could have caused it, VTEC is engaged by oil pressure, so if youre leaking oil, youre leaking pressure.
| All times are GMT -8. The time now is 09:18 AM. |
