EVAP CODE?
i have a 98 usdm gsr motor in a 96 civic hatchback and have manage to fix all of the codes except for the evap code... The reason being is the ecu is looking for a fuel pressure sensor in which my single cam gas tank does not have .... are there ways around this code so that it will not come up during a smog check? or just to clear it completely? any insight or light on this subject will greatly be appreciated..
thanks Harrison |
Re: EVAP CODE? (boiek9)
which code number? if you do a search you'll find the fix for the fuel tank problem
i think it's 91 |
| All times are GMT -8. The time now is 05:02 AM. |
